Origo 3000 Spirit Stove - How easy are they to fit?
bobholiday
How easy is it to fit an Origo 3000? I've removed an original gas 2 ring + grill from a Westerly Centaur... will I be able to use the gimbals from that on the Origo? Or do I need to purchase the Origo ones (which seem a bit expensive IMO at £50)...
Oh, and is it worth also buying the pan holders? I'm mostly going to be using it whilst on a swinging mooring.
Thanks!
Thanks!
Don't know much about the fittings, but I would definately fit pan holders. Even on a swinging mooring it can get a bit choppy so if you happen to have the kettle on and a wave hits you it could well go flying. Boiling water all over the place can make you a bit hot under the collar
Come on over to the best place to buy and sell your boaty bits www.sailroom.co.uk
bobholiday
A man after me own heart
parents used to think I was tight fisted as a kid
I'm even worse now
My little twin burner doesn't have gimbals either so I'm working on a way of doing that myself with a couple of enclosed bearings. Can't be hard to do I wouldn't have thought. As for pan restraints, they're just bent pieces of stainless rod, so guess what I'm trying to do
bobholiday
Yep, you sound like me
Only problem is, I'm lazy too so have to fight the urge to bodge!
Gimbals - the gas twin hob I removed (to comply with insurer's demands) was gimbaled simply by having two metal rods protruding from it, sat in U shaped slots. Can't imagine you'd need to go to the trouble of using bearings.
Don't forget that you need the stove much lower than the point of rotation, otherwise once you stick a pan on and the centre of gravity is raised, it'll roll more than the boat and could lead to obvious issues.
Glad you mentioned that, must admit I had forgotten about the weight of the pan. May well have to add extra weight or restrict the movement of the hob a bit.
Bit on the lazy side here too
though I tend to like fiddling with stuff to make it do what I want
bobholiday
Good thinking, I like it. And it just so happens I have the materials to do it
It can be useful to fit a gimbal-stopper to a stove just to tame it when conditions are quiet. Mine has a simple barrel bolt that can slide into a hole in the surrounding fibreglass. It's especially useful when you open the oven door, which otherwise upses the balance considerably. I still don't have areliable way to extract the roast in rough weather so I still rely on pot noodles for sustenance when it's lumpy.
bobholiday
I can't believe you'd even consider a roast! Best I've managed on the go so far has been the odd cup of coffee! Pot noodles a good idea in principle, but they're so bloomin awful I'd rather wait till I get to port. I'm only making half day voyages at the moment though.
Oh, one thing I found which is easy to cook, makes very little mess, stows well, doesn't spoil, tastes good, and is good for you is...
Popcorn!
Teeny bit of oil, medium heat, 10 mins, sprinkle of salt. Gorgeous healthy snack!
I guess a can of soup would be pretty decent on a voyage. Stick it in a mug with a spout and it'll keep its heat and be easy to consume at the helm, even in bad conditions.
Popcorn!
I prefer the home made pot noodle myself. Just get some Batchelors noodles and stick them in a pot with water, add peas and sweet corn, chuck in an Oxo cube and there you have it. Three minutes cooking, strain and bung on a plate, add a bit of cold chicken and you have a very nutritious meal that tastes good toocpedw wrote:It can be useful to fit a gimbal-stopper to a stove just to tame it when conditions are quiet. Mine has a simple barrel bolt that can slide into a hole in the surrounding fibreglass. It's especially useful when you open the oven door, which otherwise upses the balance considerably. I still don't have areliable way to extract the roast in rough weather so I still rely on pot noodles for sustenance when it's lumpy.
Haven't tried doing popcorn for years, mainly because I could never get the toffee mix to work and I have a sweet toothbobholiday wrote:I can't believe you'd even consider a roast! Best I've managed on the go so far has been the odd cup of coffee! Pot noodles a good idea in principle, but they're so bloomin awful I'd rather wait till I get to port. I'm only making half day voyages at the moment though.
Popcorn!
bobholiday
Couldn't agree more about the salt, some things are worth paying more for, but I'm not so sure about sticking it on me popcorn
I'll have to see if I can find a toffee recipe that works and give it a go.
Still got all me own teeth though
