Low engine revs in gear
Posted: Sun Jul 27, 2008 6:33 pm
I share a boat with a friend, and last month he ran out of diesel whilst motor sailing. The result was that he sucked up a lot of sludge into the primary fuel filter. We filled the tank, but there was a big difference in revs when in neutral and in gear. I guess that sludge had been sucked into the filter. Since then we have changed that filter and even cleaned out the tank. Finally, we got ready to go out again. However, when in neutral we get about 3,500rpm, but when in gear under load we are still only getting 2,500 rpm. The engine sounds fine, and the power does seem to be there - not like it was before we changed the fuel filter. We live in Spain and the weather has been very warm recently. I am thinking that the problem 'now' has nothing to do with the filters, but more to do with the huge amount of growth on the hull and probably the prop. I think I already know the answer, but I just want a second opinion. Basically, can a very dirty hull and prop have such a big effect on the revs you'll get when under power. Thanks.
