Scandic 58 yacht
Posted: Thu Apr 23, 2009 10:02 pm
Scandic Yachts
Scandic 58 Classic is a motor yacht with a flybridge. The yacht is specially designed to meet the requirements for luxury, well being and for high speed. To enhance its performance, this boat is outfitted with all the necessary additional equipments.
The yacht is made of reinforced fiber polyester (frp); as the main hull and upper structure are made of frp material and built in sandwich-construction with comb-board of the same material. The shape of the structure is V model single bottom.
The hull and the upper structure are covered with white gel coat for extra protection against water encroachment, ultraviolet radiation and aging... The resin layer adopts water-fast unsaturated polyester resin and surface mat, the back layer is pasted with a water-fast unsaturated resin and non alkaline fiber glass
The yacht is equipped with two Volvo 575 HP engines, double propeller double rudder and advanced communication and navigation systems. The line type of the appearance of the whole yacht is smooth, the main tone of the yacht white; the cabin is decorated with imported good quality teak.
The sleeping quarters are fit for eight passengers. There are two large cabins in the lower deck; both fitted with double-beds and 19" LCD TV. A small cabin with a single bed is located adjacent to the staircase and to the master cabin. In the mid upper cabin, the sofa in the saloon is designed to become a sleeping bed for two, if needed.
Two large and excellent bathrooms, fitted with showers, are located, one adjacent to the master cabin, and outfitted with a washing machine, and the second one is next to the guest cabin, aft of the vessel.
Another small shower is located aft of the main deck.
The saloon area in the main deck is brightly designed; as it offers excellent comfort and bulky space. It is equipped with white leather sofa. This same space contains one 32" LCD TV set, a DVD player, a large remote controlled projection screen that can be used as a curtain, a video projector, bassbox, 10 Hi-Fi loudspeakers with two located outside the saloon, wireless internet connection for about 30 computers in the United Arab Emirates area and a color printer.
On the same deck, the galley area, located just aft of the helmsman’s seat, is outfitted with all the necessary appliances.
The four sides of every sleeping cabin, the furniture as well as the floors, inside and outside the main deck and the fly bridge, are decked with stunning teak wood.
Light colored leather is used not only on the sofa and in the ceiling of the main deck saloon cabin, but also in the sleeping quarters as well as on the flybridge sofa.
A sidewalk on both sides of the shipboard leads to the sunbathing area on the main deck, above the master cabin. On top of bulwark, there is a safety handrail and fender mooring horn.
The flybridge is larger enough and comfortable for sun bathing and relaxation. It is fitted with a pilot seat and controls, a white sofa, with tea table and awning.
An integrated bathing platform with deck in solid teak is connected to the main deck with telescopic stainless steel ladder.
The yacht was built in full harmony with the strong standards set by the company and it is CE classified B-Class and made for the European market.
General information and craft data:
Name of model: XGYACHT580
Craft design category: B
Mass of the craft in the light craft condition: 23900kgs
Maximum recommended load: 3260kg
Mass of the craft in the fully loaded condition: 26740kgs
Vessel type: Motor Boats with Fly Bridge
Designer: Italian design
Model: Scandic Classic 58
Year constructed: 2007-2008
No. of engines: 2
Hull material: Glass Fiber
Hull type: Deep-V
LH: 17.60m
LMAX: 19.10M
BH: 4.50m
BMAX: 4.55m
Depth: 2.30m
Draught: 0.90m
Length at waterline: 15.28m
Generator: 20kW
Tank capacity
Fuel: 2500L (1250L X 2)
Fresh water: 500L
Holding tank: 500L
Maximum number of persons: 10
Main engine VOLVO PENTA:
Type: D9-575
Number of engines: 2×575HP
Rating power: F575HP/423kW
Rating rotate speed: F2600r/min
Cylinder: F6
Exhaust: F9.4L
Compress: F17.4:1
Consume: F212g/kW.h
Main engine starting: 24V
Dry weight: F1075kg
Gear box deceleration rate: F2.05:1
Outline size (length*width*height):F1710~858~970mm
The Price is 850,000 euros
for more information just call +971505211343 ,ubai1982@hotmail.com
No. of engines: 2
Hull type: Deep-V
LH: 17.60m
LMAX: 19.10M
BH: 4.50m
BMAX: 4.55m
Depth: 2.30m
Draught: 0.90m
Generator: 20kW
Tank capacity
Fresh water: 500L
Holding tank: 500L
Type: D9-575
Cylinder: F6
Exhaust: F9.4L
Compress: F17.4:1
Consume: F212g/kW.h
Dry weight: F1075kg
